Although I dont have the size offhand, the one up underneath is for timing the ignition...the one that one can see looking down from the top is the mount to the timing cover.
I had a problem with the crankcase vent...for a while I ran a breather cap on a hose in place of the stock breather hose...so the hose came up most of the way to where it was stock and then a breather cap, like you find in a valve cover, was added and clamped into the hose.
Worked fine.
This was before I found a new pcv valve and sorted that part out correctly...I think you are saying you dont have one or see one...it should be in the hose from the oil fill cap neck to the intake....see the -20 manual, fig 2-17...that shows it...It is in Chapter 2, Section 11, Maintenance of Fuel System.
