Results 1 to 10 of 41
Thread: Power Steering
    Default Power Steering
    I am certain someone has done this before. I searched FAQ and didn't find anything. How does one add power steering to the M715? A guy in Omaha said he used the pump and gear box out of a Jeep J10. That seems a little light to me. Before I get chastised for being a weenie arm, the truck has 39" x 19.5 Mickey Thompson tires. Some help turning in the grocery store parking lot would be nice
    Quote Originally Posted by JDCustis View Post
    Membership to a local gym will do wonders for the armstrong powersteering system on it.
    The J-series of P/S boxes is what a lot of guys use when they convert over. The box will bolt right on using the three stock steering box bolt holes. For more strength you can drill a 4th hole and sleeve it. P/S box has 4 bolts, manual steering box has 3. For rock crawling and/or really big tires guys run a ram assist too but you shouldn't need too unless you are one of those guys.
    I got my box off a 84 Grand Wagoneer, bolted right up. I did have to divot the crossmember just a little for it too fit but usually you don't. I just heated it up a little and gave it a few whacks and it was done, took about five minutes. You will have to change your shaft some where it bolts up to the box. I used Borgeson u-joints and a collapsible shaft for mine. Just cut the stock shaft off not too far from where it exits the column in the engine bay.
    Lindale, Texas
    power steering box and pump off of most any fill size gm car will work. it's the same Saginaw box. pitman arm will have to be changed from gm to a full size jeep and will bolt on, spline count is the same. some ford bronco full size trucks use the same pitman arm, i can't remember the year spread however. i would imagine the search function will tell you more than you want to know. there have been multiple threads about adding power steering.....al
    If you really need PS, there are offers for vintage cars to install a electric PS. If it fails the steering will be exactly the same as prior to the conversion. But it isn't cheap!!
    http://www.ezpowersteering.nl/index.php?p=2
    Feb 2009
    Northern California
    http://www.ezpowersteering.nl/index.php?p=2&lang=us works better for most people on here - English!
    That seems like a nice idea, but it has a lot of stuff I would say isn't needed, such as speed-sensitive assist (more wires) and crap like that...
    --Randy
    Fort Smith, Arkansas
    I didn't need to modify the shaft at all when using a box from a 77 Waggoneer. The pitman arm is the issue. Mine from the waggy is a little shorter than stock so I lost some turning radius. It turns easy though.
Tags for this Thread
