My weekend project last weekend was to get 8 tires mounted on my newly powder-coated stock wheels. Project was a success for the most part. Mounting the tires was not very difficult and I still have all of my body parts so it was not as scary as it sounded in some posts that I have read. Here are some photos of the operation.
Here are the wheels that just came back from the powder coater. The color is good but the finish is a little shiny. He said that if I bring some more in he may be able to dull the finish a little to match the original OD color.
Here is the cheap HF tire machine that I used to break down the eight wheels. I have been unable to get the night one broke down. I think it may car to a commercial truck tire shop along with the remaining wheels that are still on my trucks. As noted in previous posts breaking these tires down can be a real bear. I only had one that came apart easily. Hopefully with the powder coating on the wheels all future tire changes will be much easier.
Here is a Michelin 11x16.00 XL tire prior to mounting. I bought a set of five of these tires from a local MV enthusiast who said they were too large for his M37. They are big tires and heavy - will not get much sidewall flex with these.
Here is the tire mounted on the rim with the lock ring ready to be installed. The biggest difficulty I found with the mounting was getting the lock ring installed without totally scrathing up the coating.
I tried installing the first one with a bar and quickly found that that did not work very well.
After trying several different methods I finally found that standing on the ring and using a porta power to separate it made for a clean and easy install with only minimal paint chipping. Also it helps to have an assistant to pump the porta-power - I did one by myself but quickly found that I did not have enough hands and feet to keep everything in place.
I wrapped a chain around the wheel and ring prior to inflating the tire in case it tried to come apart on me.
I found that a couple of taps on the tire when you first start inflating it helped the bead slide over the ring. Once the bead is over the ring it is locked in and really cannot go anywhere.
