Hi, I'm looking for a source to get wheel cylinders. PM me with any info. Thanks.
NewStar makes new wheel cylinders which you will have to order. Or you can do the upgrade/conversion to the Ford cylinders
Wheel Cylinder Conversion
AB Linn on eBay is a great vendor for parts
I got wheel cylinders from A. B. Linn. They appear to be made in China. But what isn't. It has been too cold here to install them so I took each one apart and cleaned them with denatured alcohol. They had some yellow stuff inside, may have been honing oil. When cleaning them, the surface of the bore was dirty because the rag was gray when cleaning them. I continued to clean until the bore was clean, no residue. Then, they were lubricated with new brake fluid.
Tomorrow, I will get the number off of them. I suspect they are a standard 1-1/16" bore wheel cylinder meaning a cross to another number. There is a right and a left.
Thank you!
Wheel cylinders that I got from A. B. Linn are numbers S-C417 and S-C418
Newstar# *** Wagner# **** Ref# ****** Industry#
S-C417 ***** FS59402 **** 943652 *** 59402
S-C418 ***** FS59403 **** 944578 *** 59403
