I am mounting Chevy 3/4 ton front springs under my truck, moving the spring mounts under the frame, and putting the shackles to the rear of the spring. I am mounting the top of the spring shackle through the frame at the rear similar to Ryanroo's. I purchased some front spring mounts from Ruff Stuff Specialties.
My question is this: I would like to keep the front hangers as tight to the frame as possible, but if I do, the front spring eye will be higher than the rear. I looked on line for information on leaf spring geometry, but I am still not sure if it is OK to mount the front spring eye higher than the rear. There seems to be differences of opinions. I have things in place now (vice gripped in place) and it appears the caster would only be a couple of degrees from where it needs to be. I figured I could correct that with shims.
Anybody have some advice? I am new to much of this and I greatly appreciate all I have learned from reading everyone's posts. Thanks
