I have been gathering parts for a while now and haven't been around long enough to do much. I am finally getting the time and going to start the build.
I have 2 questions before I get knee deep in this build.
I have a 90 Dodge 6bt w/ 727 trans. I also have a 95 F800 ford w/ 6bt and a Fuller 6spd trans. I bought the F800 for the trans and the 6bt has a bad cylinder and burns oil. I am not looking for much over stock power now but I know that I will get bit by the horsepower bug and want more in the future. I was quoted that 2000$ would fix the 95 6bt. I am wondering if it would be a good idea to swap the 95 6bt parts (head, pump whatever else) onto the 90 block or just fix the 95 6bt and use it. I hope some of the Cummins guys can let me know which way is the best way to go. I am sure it isn't as easy as swapping parts even though I heard that the Cummins engines have the same block and a lot of other similarities.
Next piece of advice or opinion I am looking for is; do I swap the M715 body on the F800 frame with rockwells and build myself a 25,000 lbs GVWR truck or stay with 1 ton axles under the M715 frame and get a diesel powered 1 ton? I am looking for a work truck/ expedition type vehicle that can go most anywhere. I know I won't necessarily need the 25,000 GVMR but it would definitely be solid. There would be a lot less fabrication with swapping bodies.
