The 715 doesn't have any locks on the doors. The ones they are showing on your links are the correct ones for the Wagoneer/J-truck - and 715 if equipped for locks.
You will need to find a mechanism for a Jeep Wagoneer or j-Truck. Cut - splice - weld the bits to make it work. Haven't installed mine yet, but have cut them and welded them back together.
(You will also have to cut a round hole in the door to install the lock.)
Snuffy
Reason: Additional info.
Cummins - Turning fuel into noise since 1930.
