Does anyone know where I can buy the leaf spring u bolts for the front and rear axles? Also looking for the plates.
Thanks.
Thanks.
ABlinn has the ubolts for the rear, you can get direct or he sells them on ebay. do a search under u bolts on the site, the fronts are the same as an early cj, and the specs will be found in the posts.
Duane
I have a set of rears that I would sell...nos...pm if interested.
Just so you know, the rear ones do not have the bend in the top like they have when installed...none of the suppliers sells them with the bend...
Do you mean the bend at the bottom so the ubolt goes on the tapered part of the axle? if so the ones I got from ABlinn had them, they only go on the outer ones.
Duane
Never seen a supplier, or heard of one, with the bend...it is bent on the closed end, the curve of the U.
If thats what AB Linn has, good info...people have always advised to bend them in the past.
yes,thats the ones ab linn has, a couple other vendors have them too, they come in the original jeep bags, two of them bent, with washers and nuts.
Great info...thanks for posting this!
