Results 1 to 10 of 14
Thread: Where to get replacement differential gears?
    Default Where to get replacement differential gears?
    Well, I was planning to change out my stock differential gears from the 5.87 to the 4.56 gears (I think this is the ratio that's still available).
    But...Reider Racing has gone bankrupt and is out of business (phone on their site now redirects to 4x4.com who told me they couldn't help me).
    Does anyone know what part number I'm looking for or any place that would know what gears I'll need?
    Thanks in advance.
    --Wintermute
    Google Randy's Ring & Pinon
    I heard the 4.56's are geting scarce as well...
    New Haven, CT
    Partsmike.com I just bought some 4.56 for the rear D70 from him.
    Mikel: how much did they run?
    Come and take it
    Some time ago I've read, the front is just a dana 60 4.56 ring and pinion
    the rear is a dana 70 1/2 offset ring a pinion... make sure you get the half
    inch off set ones otherwise they won't fit.
    part numbers for randys ring and pinion.
    YG D60-456 $282.09 (front)
    DS 706997-2 $416.05
    Dana 70 4.56 1/2 Ring & Pinion KIT (rear)
    Try a search with the numbers on randys website to get the right stuff
    front: http://www.ringpinion.com/Search_Res...ase=YG+D60-456
    rear: http://www.ringpinion.com/Search_Res...se=DS+706997-2
    Not cheap...
    New Haven, CT
    Quote Originally Posted by gonz View Post
    I think it was $285-300 from Parts Mike. If you order, remind him about the pinion offset (0.5?)
    Thank Mikel and N2S3!
    Come and take it
    New Haven, CT
    You are welcome. I think the price I posted was for just the gears.
    New Haven, CT
    I found Partsmike's email (I was buying two sets):
    M715 D70: $376.00 X 2 =$762.00 this includes the ring and pinion, bearings, shims, seals and nut/washer. - 4.56 gear set
