I need to pull manifold vacuum from my new quadrajet....where do I grab it?? Is there a port on the q-jet where I can grab it, or on the manifold itself (too lazy to open the hood right now.
carb has the following ports:
Diverter port (not used)
EGR Port (not used)
PCV Port (in use)
Canister Purge (not used)
Distributor Port (in use)
Power Brake Port - 1/4NPT (not used, but will prob. go pwr brakes in future)
This is for dual-fuel conversion...manifold vac to a vacuum solenoid, when "on" it puts vac. pull on mixer diaphragm to lift it when running on gasoline.
