Results 1 to 7 of 7
Thread: distributor problems
    hello
    i have a 1967 kaiser m715 and i need to remove the stock distributor. i have followed the online instrucion manuals but it will still not come out maybe some of you have had a similar problem and could give me some tips/tricks that you used to remove your distributor. it seems to me that the shaft has either rusted or seized itself to the housing does this sound plausable to any of you?? i don't know but any help is better than no help.
    thanks
    brad in iowa
    Default distributor problems
    Small amount of heat to the timing cover.
    or
    Channels locks and rotated it.
    or
    18" block of wood from the bottom side and tap it out.
    If you are planning on reusing the dist, the first is probably your best bet for not destroying it, But I have used a combination of the last two without hurting anything, just go easy on it.
    thanks for the reply and i asked some locals and they said to put the #1 cylinder at tdc and then try to remove the distributor would this help?? it doesnt make any sense to me but then again i don't have a clue anyway so...
    thanks
    brad
    -brad
    '86 & '98 Ram 4x4's
    Default Parts Washer
    Won't help a bit in removal, helps you line up the rotor and timing on reassembly.
    How far from Newton are you?
    Doug in Iowa
    i live in dubuque but i got the distributor out and replaced the coil and condenser and reground the points but i am only getting the spark to go to #1 cylinder and i heve only one idea and that is to clean the contacts on the rotor and the distributor cap but other then that i am completely lost as to what may be wrong any ideas??
    thanks for the help fellas
    brad in dubuque iowa
    -brad
    '86 & '98 Ram 4x4's
    Sounds like cleaning the cap would be the most logical step. I "think" I have a extra working distributor. I'll check my stash and let you know.
    thanks while you are looking please look for a wires set for me too if it ain't too much trouble. any way if you have either that would be appreciated
    thanks again brad in dubuque iowa
    -brad
    '86 & '98 Ram 4x4's
  1. Can't get distributor off 230
    By robsgp in forum Open Discussion
    Last Post: December 1st, 2014, 08:03 AM
  2. V8 problems
    By scottsmyth in forum Modified Tech
    Last Post: June 23rd, 2009, 12:04 AM
  3. Need a distributor cap
    By viperman in forum Stock Tech
    Last Post: February 4th, 2008, 02:45 PM
  4. distributor help!
    By fwdstuck in forum Stock Tech
    Last Post: March 14th, 2007, 01:49 PM
  5. need a distributor
    By 4x4wheelin in forum Stock Tech Archives
    Last Post: March 26th, 2004, 10:33 AM
