Well, kind of ironically, I was on my way to get my truck inspected for the year when the engine seemed to be breaking up a little, let off the gas, ran fine. Got some gas, got the sticker, the breaking up started again, but much worse. I pulled over at the best spot I could find. Here is the run down-
-230 with a holley 2300 style carb
-Engine breaking up/ backfired once or twice.
-I have a clear filter in the line between the pump and the carb, you could see bubbles in there, checked all the fittings I could get at for tightness, no leaks to suck air through.
-Blew air back through the line, didn't seem like it was blocked at all, after getting it started again, the bubbles were still there.
-Took apart the tank to fill neck vent (It did have gas in it), nothing different.
-Had to start it by pouring gas in the carb once or twice while monkeying with it, sometimes it would run and break up, sometimes not.
-I was going to try a fuel line from the pump into a gas can but I didn't have any fittings to try to safely rig that up and my help's patience was running out.
-This happened twice before, last fall, when the old carb was on it, so I don't think its the carb. Both of those times were after long periods of idling, or not moving very fast and I chalked it up to the gas vaporizing.
-I rebuilt the fuel pump like 3 years ago, but with a kit I bought from Ebay that came in a sandwich bag.
-I noticed since I put the clear filter on that the gas backflows through it when the truck isn't running, usually if I had it running the day before, the next day it would be empty, no leaks on the garage floor.
- A nice local gentleman in an MVPA hat stopped to help, his best guess was new gas+old rebuild material= This.
I ended up getting a buddy with an F250 to pull me back to a fire company I belong to. As luck would have it, I have a spare fuel pump "in the mail" from a member. Does it seem logical that the fuel pump is the problem, or should I be looking at the line more?
Edit: forgot to mention that the fire company (I learned not to call it "hose house" around Doug) has an M715 brush truck, and I had to fight the urge to start swapping parts around.
