Here's my experience:
I have a 3000 Sq Ft shop. plumbed with air in every corner. I have an 80 gallon 2-stage compressor with a 6 HP motor on it, 240 volts. Where the air line leaves the compressor it is 1/2" all the way to everything. I used copper pipe for all the air lines.
I have one huge air consumer, and that is my bead blast cabinet. Its a circa 1973 Trinco cabinet that will fit most motorcycle frames inside it. When I blast with it, which is pretty much every single day for at a minimum of 2 hours, sometimes all 10 or 12, the compressor will run nearly constantly. I added another 60 gallon tank to the system last year. This kept the compressor from kicking on quite as soon, but it also made it run twice as long to fill two tanks now. Lots of volume, same pressure.
If someone is blasting in the cabinet for any length of time, there is a noticeable difference in the performace of any air tool anywhere else on the line until the system recovers.
Just make sure you have more than you think you'll ever need is my point.
