I have a 24 volt Faucet pump and it has worked great for the last 4 years. Friday, however, I changed the filter closes to the carb and now the pump will not shut off. It just continues to push fuel to the carb. It use to shut off when the lines were pressurized. It is a self priming pump so not sure what can be causing this. Air in the pump? Thanks.
