Results 1 to 4 of 4
Thread: Cucv axle backspacing
    Default Cucv axle backspacing
    A question that was asked that I didn't see an answer to: if you swap in the slightly narrower cucv axles, does it change the tire clearance on turns?
    Do you need to run wheels with less backspacing (around 3-4") to maintain the stock axle wheel stance and keep tires from rubbing? I plan on using my 11.00-16 xlz's. Thanks!
    Jan 2007
    Fort Smith, Arkansas
    I think Jpete is doing this swap and using dually hubs up front to get the wms out far enough to use Hummer wheels. I haven't seen any more on it since last fall when he wrote about it in JP magazine. You might check their website and see if he's made any progress.
    Simplest solutin is just get wheels with 3-4" of backspacing. Stock wheels have over 5" of backspacing.
    Dec 2008
    ST LOUIS,MO
    I have 325 85 16 michelins on 16x10 wheels with 4 inch backspacing and my tires stick out past the wheelwell.
  1. cucv axle (again)
    By blairdes in forum Modified Tech
    Last Post: March 2nd, 2009, 11:23 AM
  2. Backspacing with CUCV axles?
    By Grantshire in forum Modified Tech
    Last Post: January 11th, 2008, 09:27 AM
  3. CUCV Axle ?'s
    By Jay Dog in forum Modified Tech
    Last Post: January 7th, 2008, 05:09 PM
  4. cucv axle ?
    Last Post: June 24th, 2007, 12:06 AM
  5. CUCV Axle Swap
    By kalikraven in forum Modified Tech Archives
    Last Post: February 7th, 2004, 11:25 PM
