Results 1 to 10 of 21
Thread: heater control cables and switch question
    Default heater control cables and switch question
    I am getting ready to install my heater that I got from a FSJ, will need the control cables, can anyone tell me if the stock cables were labeled? (defrost, heat etc?) or were they just plain cables, and does anyone have a source for them?
    Thanks
    Duane
    also was there just a one speed toggle for the fan or was there speeds?
    Fan is on or off...
    The cables are marked:
    Heat
    Defrost
    Fresh Air Control
    The knobs are, basically, OD Green.
    The cables are standard choke tye universal cables EXCEPT for the knobs being green and labeled and the ends of them are bent around in a circle or 2 instead of being just a straight end of inner cable sticking out of the outer sheath.
    If you want a pic or lengths, let me know.
    Are you askinga bout stock civilian parts?
    If so, there are no cables (except the blend cable that opens the main door to the heator core housing). The defrost, off and air(heat) settings are controlled by vacuum.
    The civilian heater fan has three speeds.
    1963 J300/1971 J2000/1983 J10
    Being this is the stock tech board, it would be stock to the M715...if posted in the correct forum...
    Jul 2009
    Louisville, KY
    Can a vacuum newer heater be adapted to the use of control cables?
    Thanks for all the help!
    Most likely the civ. vac controlled ones just had a vac. daspot added that connected to the same post the cables did(?), you would need a way to attach and secure the cable there in place of the daspot. The early civ. vehs. did use a control panel which just bolted to the bottom of the dash you could use that and run a vac line off your wipers and have the system oper. w/ vac I would think, but I hadnt ried that.
    68 M-715 MVPA #2710
    Just wanted to make sure, as he said he is using a civilian heater. That could mean he has the entire set up.
    I bought a heater setup out of a fsj, and trying to install in my 715 as it would have came stock, thats why I am intrested in the correct cables, I am going to use the toggle for the fan like a stock one.if anyone has a source for the cables with the print on them I would appreciate it.
    Thanls
    Duane
  1. m-725 heater conversion question 24 to 12
    By KYSAR725 in forum Modified Tech
    Last Post: February 17th, 2010, 07:00 PM
  2. Hot Water Heater Installation Question
    By BlessedM715 in forum Stock Tech
    Last Post: January 15th, 2010, 10:37 PM
  3. osut362 : heater/defroster cables
    Last Post: November 13th, 2009, 01:55 PM
  4. barrman : Heater Fan Switch
    By Barrman in forum PseudoZone - Open Archive
    Last Post: November 12th, 2009, 01:46 AM
  5. heater question, what fits?
    By Duane in forum Stock Tech
    Last Post: January 21st, 2009, 01:41 AM
