Results 1 to 10 of 16
Thread: spare tire mount rear attaching pic
    Default spare tire mount rear attaching pic
    ok, can someone post a pic on how the rear part of the tire carrier attaches to the frame? is there a bolt? or a catch? I do not have a hole in my frame where a bolt would attach? any help would be appreciated
    Duane
    Jul 2009
    Louisville, KY
    On my bumper,below and right of where some idiot used a torch to rid of the pintle hook is a bolt hanging. That is where the tire carrier rests. The other end is the bracket just above and to the left of the pumpkin. Hope this helps...Ken
    Thanks for all the help!
    Springdale, Arkansas
    Hey Ken, is that you in the pic?
    Jul 2009
    Louisville, KY
    No, but we do have the same barber ; p
    This was the 1st time I drove the truck back in November '09. I went around the block to a shop for a complete lubrication. The only changes since then noticable in the pic is a new exhaust system and tires. How do I fix that darn bumper/pintle? Guess I need an artist with a cutting torch and a welder.
    Find a scrap frame with a good rear crossmember and replace yours with donor trucks.
    So the carrier runs on an angle to the right side the pintle, I was thinking it ran straight back, I am assuming you need to tighten and loosen the nut to remove the hanger.
    I will look for the hole in the frame when I get home.
    Thanks
    Duane
    Actually its a bolt that goes in the frame...kind of long...think I have an imagine somewhere...maybe later I can post that...
    Yes, it runs at the angle.
    luckily, the hole is there and the threads are intact, anyone have the lenth of the bolt? if not I will figure it out when I put the tire up
    Thanks for the pic and info
    Duane
    I think I posted those once...lets see...
    Well...I dont see the specs off hand anymore...but I do have the pic of the bolt:
    Maybe someone else can measure for you...
    I found a thread that has pics of an installed carrier...not the best but it might help...and this is with an oversize tire and the stock carrier is modified a little but it does how the basic idea.
    http://m715zone.com/vb/showthread.php?t=6758
    Heres an even better pic of a stock mout in place:
  1. Spare Tire Mount for 38-Swamper
    By dummy in forum Modified Tech
    Last Post: March 11th, 2008, 10:25 AM
  2. Spare Tire in Bed
    By dhood in forum Modified Tech
    Last Post: August 3rd, 2007, 02:28 PM
  3. Moving/Re attaching rear arched Cross member
    Last Post: May 7th, 2007, 09:04 PM
  4. M-725 spare tire
    By rpgdeity in forum Stock Tech
    Last Post: February 28th, 2007, 05:26 PM
  5. spare tire hanger
    By rjenkins in forum Modified Tech
    Last Post: January 7th, 2007, 09:23 PM
