Results 1 to 8 of 8
Thread: will a 3 lever headlight switch work with 12v
    Default will a 3 lever headlight switch work with 12v
    in my transformation back from fire truck to close to stock, i would like to reinstasll a 3 lever headlight switvh in place of the pull jeadlight switch my dept put in when they built it. will it work with 12v only thing I was thinkiing may not work is the panel light dimmer, but wasnt sure, has anyone converted to 12v and left the stock switch in?
    Thankis
    Duane
    sorry about the spelling, i cant see without my reading glasses and the black key board makes it hard to see in low light
    Duane
    Yes, the 3 lever light switch works fine on 12 volts.
    The only problems for an M715 to go 12 volts, besides the bulbs and ignition, are the gauges and sending units, heater blower motor, if equipped, and the turn signals IF the early style distribution box is on the truck. This is a large rectangular box mounted next to the master cylinder with 2 vertical rows of screws with wires attached to them...like 10-12 wires on 10 screws or so. There is a page on converting this style to 12 volts and also a page on swapping to the later style as well in the Online Mainrtenance Manuals link at the top of the page.
    If it has the smaller rectangular box with a 3 wire cannon plug screwed to the bottom, then it is the later style solid state unit and will work fine on 12 volts.
    actually, it was converted in the 80's when it was converted to a brush truck by my dept, I am putting the correct lights on it with 12v bulbs, the blackout lights, etc, and would like to put the 3 lever swtich back in it. just didnt want to go buy a switch and find out it wont work on 12v for some reason. now I will hunt for a switch.
    Duane
    The dash light dimmer might or might not work on low with 12V. My 12V M715 with Auto Meter gauges does not light up on low. However, the gauges we have installed in the 12V truck for Pistolnut do work on low. I don't know why. Expect either, but don't worry if low doesn't work. You can't see anything on low with 24v anyway.
    when you buy the 3 lever light switch, you also need the plug that screws into the back side. Assuming the wiring harness is hacked up and it is missing
    Feast or famine,
    Quote Originally Posted by chimesickle View Post
    They are available.
    I have a spare harness, The Dept got 2 trucks and took one apart for parts, I may just keep the harness complete and buy the headlight plug with the wires.
  1. Headlight switch and turn conversion
    By CHRIS UNGER in forum Modified Tech
    Last Post: March 22nd, 2010, 08:02 AM
  2. Replies: 10
    Last Post: November 2nd, 2008, 08:40 PM
  3. Headlight switch breaker?
    By the1968jeepthing in forum Stock Tech
    Last Post: November 3rd, 2007, 04:13 PM
  4. Steering column and headlight switch
    Last Post: October 28th, 2007, 10:55 PM
  5. multifunction headlight switch
    Last Post: June 13th, 2007, 09:46 PM
