I put on Selectros without changing any studs...used spacers on the long ones but the short ones were fine.
I do remember that the washers on the short studs had to have one side ground flat to fit between the stud and the hub.
I do agree that the bolts are much better in the long run that the studs...less to worry about and less to damage (in this case, to the person) with bolts...unless you want to make a tool like Gimpy has for turning the hubs:
