Looks like a crazy mix of civvy and MV.
Think it could be a proto-type that Kaiser tried to come up with to keep the vehicle contract?
Have to say that I like the changes to the interior. Bench seat, e-brake, and battery box.
भगवान तुम्हें प्यार करता है
yep that battery box is nifty. Albeit small for todays batteries. me thinks this is Johnny cash's m715. got it one piece at a time. You know.......68,69,70 automobile. Snakeater
COWBELL, you need more of it
The front valance is civilian, even has painted over lenses in the turn signal area instead of metal. That seems very odd, like it has been replaced, that would explain the hood, which is a stock razor type FSJ hood. Does it have the holes drilled for the blackout light on the hood? Maybe a possible front end collision replacement job?
The solenoid goes to the starter. Is it also different than the normal setup? I have not really researched that yet.
It looks like the holes for the blackout light were in the hood at one time. The underside of the hood is rusted and rough in that area. I need to take a sanding wheel to it and clean it up to see if the holes were welded shut at some point which is what appears to have happened.
The e-brake lever is from something like a M105 trailer. I like the idea better than the stock setup.
The passenger seat is a M35 deuce passenger seat.
The battery box is likely designed to fit 2 2HN batteries. Some pictures in the manuals show the 2HN batteries while other pictures show the 6TL batteries found in the M35 trucks. That battery location is a nice idea. Although it eliminates storage of the top frame and bows behind the seats.
As for the side window it looks like someone tried to make the left side fit the right side without success.
I don't see a starter button on the tranny cover just above the shifter (there is a cover plate there). Is there a keyed ignition on the truck?
There is no starter button on the floor. No keyed ignition switch either. The ignition switch on the dash operates the starter. I thought the same thing about the window but both doors have the same fixed window situation and there does not seem to be anyway to easily reverse them.
I don't think that is a Deuce passenger seat. The hinge looks just like the stock M715 seat frame. The deuce seat has a flat metal hinge/support.
Also, anyone notice the bolted on front spring shackle mount? Very unusual.
Data plate is brass too. All of the stockers were aluminum.
The top of that side door glass is slanted. I don't know what that was designed to fit. The track for the window is on the correct side, although it could have been switched as I think that part screws on with several small sheetmetal screws. I don't remember offhand, but I do know the fixed glass is square with no angle at all to the frame.
I noticed the front axle and the rear output on the transfercase have flanges not yokes
Interesting spring mount...
Very unique vehicle! I hope you preserve it as is - I´ts certainly a piece of history.
