Results 1 to 4 of 4
Thread: are all m1008 trucks(cucv)1 1/4 tons axles
    Default are all m1008 trucks(cucv)1 1/4 tons axles
    i was on gov liquidators and some times they list the pick ups as 1 1/4 ton and other times they list them as 3/4 ton . and i know the m1009 blazers are 3/4 ton . and if so without seeing the trucks data tags how can you tell
    8 lugs and the axles are the 14 bolt and D60. 6 lugs and more heavy half than 3/4 ton.
    Locker for the front I think only came in the 1028 but am not sure.
    The 1028 has a limited slip up front. All other d60's were open.
    Georgetown, CA
    Just a side-note, the M-880, which was the dodge "5/4" really was just a 3/4 ton dodge pickup, 60 in the back, 44 in the front, .. I would recommend staying away from them as because that front axle is a PITA to work on. . .
  1. 1983 to 87 m1008 cucv pick up 's ???
    Last Post: December 15th, 2009, 11:01 PM
  2. M1008 cucv axles vers. 2.5 rockwell axels Pro's and Con's
    Last Post: December 10th, 2009, 11:49 PM
  3. cucv axles
    By militarytrux in forum Modified Tech
    Last Post: January 19th, 2009, 12:13 PM
  4. Backspacing with CUCV axles?
    By Grantshire in forum Modified Tech
    Last Post: January 11th, 2008, 09:27 AM
  5. CUCV AXLES on the M715
    By joesco715 in forum Open Discussion
    Last Post: May 20th, 2007, 10:38 PM
