would a borg waner 4407 transfercase form a f350 4x4 truck make a good choice to replace the stock np200 case in a m715 . also does anyone know the ratio of the case need to know as soon as possible
Ford stuff is driver's side drop, and the Jeep stuff is passenger side drop. Unless you have Ford axles, this will be a problem.
Yep, unless you have already, or are planning to, swap in a drivers side drop front axle then this isn't going to work for you.
As for the rest, Google is a wonderful thing.
BORG-WARNER 4407
Type: Chain-driven, magnesium case
Low-range ratio: 2.72:1 and 1:1 High-range
Lubricant: ATF
Used by: Some 1996-to-98 full-size Fords. Fixed rear output with non-removable flange. Same shift pattern as later-model BW1356s. No PTO output.
भगवान तुम्हें प्यार करता है
Should be a good stout case, but as already pointed out, it is drivers drop.
Also, You didn't say how you planned to run it, but it is a married case, so as a rule, I wouldn't consider it as a "replacement" for a 200 unless you were planning on running a complete Ford powertrain.
