Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: tomahawk715 : Painless wiring
    Default calpyro :
    Re: Painless wiring
    Post by calpyro on Nov 22, 2006, 2:18am
    I got the 21 circuit EZ Wiring kit. It is long enough for a M715. I also got the headlight and ignition switches. As far as I can tell, it was the cheapest available. it went in without a hitch. Total cost about $210
    Default compexp :
    Re: Painless wiring
    Post by compexp on Nov 22, 2006, 4:09pm
    Quote:
    Compexp-Just checkin-that kit you got from summit is a Painless kit then?? I see it says standard length-Going by what you said about mounting it under the hood it if you did it over----would it have then been too short?? I see they do have a kit listed as universal truck long....
    I see a ton of the cj kits and bronco ones on ebay but the truck ones seem rare as hens teeth
    It would be fine under the hood - because I mounted it under the dash, i then had a 3' run to just get out of the cab into the engine compartment - that 3' would give me enough for the passenger taillights.
    Default tomahawk715 :
    Re: Painless wiring
    Post by tomahawk715 on Nov 22, 2006, 10:25pm
    Ok gottcha-I see what you mean-Like I said just want to do this with no splicing.
    Default hummer103 :
    Re: Painless wiring
    Post by hummer103 on Nov 24, 2006, 2:24am
    Im running a 12 cirrcuit Painless Harness I bought a few years ago, way too many wires. I used like a third of them, Harness cost me like 300-something I think. Real pain trying to hook up some of the stock interior switches and things, but I decided to to that.
  1. Need wiring help
    By ldj1002 in forum Open Discussion
    Last Post: September 18th, 2009, 12:36 AM
  2. Turn signal switch/painless harness
    By Craig Merrill in forum Modified Tech
    Last Post: March 9th, 2009, 12:41 PM
  3. painless wiring harness?
    By spgirard30 in forum Modified Tech
    Last Post: February 8th, 2009, 06:31 PM
  4. Aftermarket Wiring Harness - Painless Type
    Last Post: November 19th, 2008, 05:50 PM
  5. Wiring
    By archjr in forum Open Discussion
    Last Post: January 28th, 2008, 07:42 PM
Copyright 1998-2022
