Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 25
Thread: robertcowan : FRONT 8 LUG HUBS THAT FIT THE M715 FRONT AXLE
    Default compexp :
    Re: FRONT 8 LUG HUBS THAT FIT THE M715 FRONT AXLE
    Post by compexp on Oct 7, 2006, 2:17pm
    so find those hubs, and they will bolt on to give us 8-lug one-piece rim compatibility?
    If so, THANK YOU BOB!
    Default robertcowan :
    Post by robertcowan on Oct 7, 2006, 6:02pm
    YEP
    Default stanman :
    Post by stanman on Oct 7, 2006, 9:13pm
    so this is a bolt on, no modification whatsoever?! COOL!
    May 2004
    Anchorage, Alaska
    Default 40grit :
    Post by 40grit on Oct 8, 2006, 12:51am
    i thought there was something about the spindles being different...back on the old board...
  5. #15
    Post by robertcowan on Oct 8, 2006, 2:45pm
    NOPE
  6. #16
    Post by brute4c on Oct 8, 2006, 2:57pm
    I seem to remeber the same thing...but I wish I had the old board....dont we all...
  7. #17
    Fort Smith, Arkansas
    Default wrecker :
    Post by wrecker on Oct 9, 2006, 10:33am
    So are they or aren't they a bolt on?
  8. #18
    May 2004
    Anchorage, Alaska
    Default 40grit :
    Post by 40grit on Oct 10, 2006, 1:30am
    let me look at work tomorrow, I have more stuff saved there....
    it thought you had to change out the spindle and machine a little to make it fit...
    somehting about a difference of a 1/4 inch or somethign comes to mind...
  9. #19
    Default bigwheelbob :
    Post by bigwheelbob on Oct 10, 2006, 6:35am
    I know I used to use the 14 bolt hubs on the front, and If I remember right, I had to make a 1/4 spacer for them. Been awhile though.
  10. #20
    Default tngreenmachine :
    Post by tngreenmachine on Oct 10, 2006, 6:42pm
    I would like to know if rear 60 hubs could be used for the 60 front. Those are pretty easy to find. I don't think I have ever actually seen a 60 front axle that old.. I would be interested in the 14 bolt conversion too even with a spacer seems like the way to go.
  1. front hubs? need info!
    By dave in forum Stock Tech
    Last Post: June 10th, 2008, 06:14 PM
  2. front lock out hubs
    By dave in forum Modified Tech
    Last Post: May 30th, 2008, 09:12 PM
  3. Moding m715 front axle
    By 503m715 in forum Modified Tech
    Last Post: April 29th, 2008, 05:55 PM
  4. How get into front Hubs and Pull rear Diff?
    By HUMMER103 in forum Modified Tech
    Last Post: February 6th, 2008, 03:43 PM
  5. m715 front axle
    By heepofajeep in forum Open Discussion Archives
    Last Post: May 24th, 2004, 10:29 AM
