Results 1 to 10 of 15
Thread: bigbabyroger : 360 jeep engine
    Default bigbabyroger : 360 jeep engine
    360 jeep engine
    Post by bigbabyroger on Nov 5, 2006, 11:54am
    A friend has a jeep 360 engine. Will it bolt directly to the t-95 trans. or would it need an adapter kit? Just wondering for future engine power. I'm not trading my 230 untill absolutely necesary.
    Washington State
    Default fisherman :
    Re: 360 jeep engine
    Post by fisherman on Nov 5, 2006, 1:08pm
    You could use the 360, pretty good engines. Use the 360 bellhousing, and put the input shaft from a t-18 onto your t-98. You would also need the motor mounts for the frame. Or just use the t-18 that is bolted to the 360 if you can get that as well. I'd go that route over a chevy engine any day.
    Re: 360 jeep engine
    Post by bigbabyroger on Nov 5, 2006, 6:11pm
    Thanks alot thats what I needed to know.
    Default kaizenator :
    Re: 360 jeep engine
    Post by kaizenator on Nov 6, 2006, 9:18pm
    Will the input shaft from the T98 go into the T18 and work with the 230 and its bellhousing? What is the length of a 230's bellhousing (is it the same as a 360's) ?
    Washington State
    Default fisherman :
    Re: 360 jeep engine
    Post by fisherman on Nov 6, 2006, 9:54pm
    Why would you want to do that? Input from t-98 into t-18 with the 230. Both those trans are about the same. I'll bet the 360 has a longer bellhousing because it is a shorter engine than the straight six.
    Re: 360 jeep engine
    Post by kaizenator on Nov 7, 2006, 8:48am
    Why you ask?...I am thinking about putting the 360 that is in my J4000 into my M715, and putting the 230 into the J-truck. The J-truck is a good flat bed work truck I use regularly and does not need the 360's power, and I want the M715 to have lots of power.
    I also have a 2wd SM420 trans, but I do not have a GM engine. Has anyone used a SM420 in their M715?
    Default tacomainoh :
    Re: 360 jeep engine
    Post by tacomainoh on Nov 7, 2006, 9:26am
    yes.
    I would just swap the J4000's stuff straight over.
    Re: 360 jeep engine
    Post by brute4c on Nov 7, 2006, 12:18pm
    The 230 uses a shorter input shaft than the 360.
    Re: 360 jeep engine
    Post by kaizenator on Nov 7, 2006, 4:23pm
    What exactly would you swap into my M715 if you were in my shoes:
    360 and mainshaft (keep T-98)
    360 T-18 & D20 (remove np200)
    360 T-18 & D20 (leave np200 and have a divorced doubler)
    I also have two 2wd SM420s
    The T-18 I have is not a T-18A. It has 4.00:1 first not the desirable 6.32:1
    ...and some day I would like to put a short granny trans behind my Buick 225 V6 in my '59CJ5 and I may or may not keep the spicer 18. I am thinking that if a T-98 is left over, I might be able to buy the correct mainshaft for the buick V6 (which is attached to a T-90 now).
    What is involved in attaching a M715 T-98 to a Spicer 18 small hole and large hole?
    Washington State
    Default fisherman :
    Re: 360 jeep engine
    Post by fisherman on Nov 7, 2006, 4:54pm
    Use the sm420 for your 225 as it is a direct bolt up to that engine, you will need an adapter however to mate the transmission to your dana 18 transfer case, I bought the Novak as it allowed more driveshaft clearance and they are great to deal with. I would also keep the t-98 in my M truck add the 360 and the t-18 input shaft with carrier bearing and new inside roller bearings to mate the two. Look for a 205, or 202 divorced transfer case to install instead of your 200 if you don't want to keep that. I'm doing or have done similiar stuff to my M truck and current Jeeps. Just my opinion. Good Luck
  1. Why would Jeep Do This?
    By rboltz in forum Stock Tech
    Last Post: January 31st, 2015, 12:10 PM
  2. bigbabyroger : 230 gaskets
    Last Post: November 12th, 2009, 04:11 AM
  3. 401 jeep v8
    By quietman in forum Modified Tech
    Last Post: October 12th, 2009, 09:30 PM
  4. jeep engine
    By armored_jon in forum Modified Tech
    Last Post: June 9th, 2008, 10:57 AM
  5. What You Keep In Your Jeep?
    By jacobo in forum Open Discussion
    Last Post: February 27th, 2008, 03:51 PM
