Results 1 to 7 of 7
Thread: teking : CJ body poly mounts
    Geneva, FL
    Blog Entries
    1
    Default teking : CJ body poly mounts
    CJ body poly mounts
    Post by teking on Oct 8, 2006, 11:50am
    ... I took the advice of someone on this board and used the CJ poly body mounts from JCW. They worked great!!! The NOS rubber (40 years old) that I installed lasted 2 weeks before they cracked all up.
    Lone Pine, CA
    Default luckypabst :
    Re: CJ body poly mounts
    Post by luckypabst on Oct 8, 2006, 4:48pm
    Looks good! You'd be farther ahead to flush your money rather than buy NOS rubber, in my opinion.
    SF Bay Area, CA
    Default hiker :
    Post by hiker on Oct 11, 2006, 12:32pm
    Teking, Thanks for the tech info! Looks good. Did one kit cover the whole truck, or just the bed?
    Geneva, FL
    Blog Entries
    1
    Default teking :
    Post by teking on Oct 12, 2006, 6:56am
    Just the bed. 14 bushings.
    ...............2..........2............2.......... ..1
    Front ............................................... Rear
    ...............2..........2............2.......... ...1
    Haven't had any trouble with the cab NOS rubber. it is MUCH lighter than the bed. I'm sure I will at some point ... I'll change those out when I need to. It took all of 30 Minutes to change out all the bed rubber to the poly. Easy because the NOS rubber had only been in there a couple weeks and nothing was rusted.
    BTW - I also used stainless bolts and washers. No need for grade 8 hardware if I'm not seriously USING the bed. I fact i put the entire truck back together with stainless. Except for places that clearly needed a higher grade bolt. For example I used Grade 8 on the bumper hardware. Linkage controls, etc. Also stainless hard and braided brake lines and fuel lines.
    The line on the firewall in Stainless. I replaced the other line finally with stainless as well ... Had to get brakes operational before I got my hands on a piece of stainless stock. Whole system is stainless now.
    Default over2land :
    Post by over2land on Oct 12, 2006, 8:22am
    What's the PN on those front flexible stainless lines?
    Looks good on the bed... I gotta do that one of these days.
    Geneva, FL
    Blog Entries
    1
    Default teking :
    Post by teking on Oct 12, 2006, 9:49am
    just call Mike at http://www.classictube.com/ That where i had the stock line reproduced. he has the templates and will make you some. Also got the hardlines and fuel lines from them. They have the M715 templates.
    SF Bay Area, CA
    Default hiker :
    Post by hiker on Oct 12, 2006, 2:27pm
    Thanks again for the info, Robert
  1. luckypabst : Poly body bushings
    By LuckyPabst in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 05:21 AM
  2. Body Mounts
    By jeepjunker in forum Modified Tech
    Last Post: June 9th, 2009, 12:02 PM
  3. body mounts
    By andy howell in forum Modified Tech
    Last Post: June 8th, 2009, 09:38 AM
  4. Body mounts and shocks
    By carmen in forum Open Discussion
    Last Post: January 18th, 2007, 09:31 PM
  5. Body mounts??
    By poolmike in forum Open Discussion
    Last Post: January 10th, 2007, 10:59 AM
