Results 1 to 3 of 3
Thread: vrod02 : 230 "Lite" rebuild kit?
    St. Louis, Mo.
    Default vrod02 : 230 "Lite" rebuild kit?
    Post by vrod02 on Nov 14, 2006, 1:26pm
    Thinking of a light motor in overhaul, Carbon cleanup,valve guides,hone and rings.IF I can find the parts! Anybody know where to find em?
    Washington State
    Default fisherman :
    Re: 230 "Lite" rebuild kit?
    Post by fisherman on Nov 14, 2006, 3:15pm
    You don't even want to know what it will cost you. Look the other way and run. Do a conversion much cheaper. Trust me I spent over 3 grand on the turd of an engine was going to do the 2 barrel conversion and had the civilian distributor and everything. I drove it less than 20 hours and pulled it out. Working on finishing my v-8 truck.
    St. Louis, Mo.
    Default vrod02 :
    Post by vrod02 on Nov 14, 2006, 3:43pm
    Found these guys.Some cheap, others out of site.
    Lite was the key word, no bearings,rods or pistons.Gaskets can be made,other than a head gasket.. Just need to find rings and valve guides. Times money.Even the full kit is cheaper than a conversion IMHO. She runs fine just puffin more than I like.
    http://www.kanter.com/wiln.html
  1. Mike's Restoration Thread, "The List", Current Progress...
    By BubbaWilkins in forum Open Discussion
    Last Post: January 27th, 2011, 04:24 PM
  2. Brake hose and throttle cable "clips"
    By rboltz in forum Stock Tech
    Last Post: December 5th, 2007, 09:35 PM
Copyright 1998-2022
