Thread: rumplecat : Blue Engine?
    Default rumplecat : Blue Engine?
    Blue Engine?
    Post by rumplecat on Oct 1, 2006, 3:13pm
    While I was changing the oil I noticed how gummed up the insice of the oil filler neck was I gave it a pull and it came right out except for the hose attached, it was not a real tight fit, is this normal? Anyway I cleaned up the neck to repaint it. the paint color under the grime was a "light" navy blue, with a little scrubbing the engine block looks the same color, was this the factory color?
    James G.
    Re: Blue Engine?
    Post by brute4c on Oct 1, 2006, 8:49pm
    Mine does that same thing...always has...I dont worry about it...
    My engine is black...blue is different but not impossible...
    Default fast72 :
    Re: Blue Engine?
    Post by fast72 on Oct 6, 2006, 9:59am
    Memphis Equipment shortblocks/longblocks are blue for some reason.
    Default damule :
    Re: Blue Engine?
    Post by damule on Oct 19, 2006, 6:43pm
    The hose that is in the oil filler neck was, I thank A wire mesh to prevent large debri out of the engine.I do know, if you shove that metal to far in the neck the lifters will hit it and then you eill be wandering were the metal came from the next time you change the oil.
    Re: Blue Engine?
    Post by brute4c on Oct 20, 2006, 8:57am
    All the 230's I have seen, military and civilian, have that screen in the oil fill hole...
  1. Cat 3116 engine swap into blue
    By snakeater in forum Modified Tech
    Last Post: January 12th, 2010, 11:20 PM
  2. rumplecat : How much Oil???
    Last Post: December 15th, 2009, 03:03 PM
  3. rumplecat : Miller 135 Mig Welder?
    Last Post: November 11th, 2009, 03:55 AM
  4. rumplecat : Time for Cab Canvas!
    Last Post: November 11th, 2009, 02:22 AM
  5. hi steer arm ( blue torch fab )
    By BCOWANWHEELS in forum Open Discussion
    Last Post: February 8th, 2007, 01:05 PM
