so i finally got a 715 and looked it over good and figured out what direction i wanted to take as far as a restoration goes. i decided i wanted it to look military with a modern twist. ive taken a 454 out of a 89 chevy pickup and bolted it to the factory tranny and moved the firewall back about 3 inches the best i can tell. its tight but everything is going to work well except for the factory fan but that an easy fix with an electric unit. my question is, has anyone done this conversion before? my motor is in and its setting on the factory mounts but they need a little work to get it bolted up so does anyone know where to find motor mounts or do i need to fab some? i think this is going to be a very cool truck when up and running but until then any guidance in any issues that anyones knows i might have will be great! this is the first time ive done a 6 cylinder to a v8 swap but not the first time to put together a project.
