Ok....your problem may be that the wavy spring in the middle of the clutch plate has sat copressed for so long that it is not longer acting as a spring to take up the shock of being clamped to the flywheel but is like a solid plate.
Mine did this...it also makes the clutch plate get hotter as it is used all of a sudden much more than it was, as the space that the spring provided in the mddle helped act as a cooling area for the plate and the lack of a give point makes more friction anyway.
My truck had 14051 miles when I bought it. In less than 5 months, it had 16000+ and then it happened...
I was cruising along at 55 mph for about 30 miles without having to use the clutch...this was 50 miles into a trip...when I pushed the pedal to coast into a small town and slow down I heard a BANG from the clutch area.
I managed to stop and heard a noise everytime I started to release the pedal...after trying 20 or 30 times, I was able to release the pedal in neutral with no new noises...I managed to finish driving the last 20 miles to where I was going...which was to do the clutch job anyway as I had been adjusting it kind of often due to it wearing quickly.
When we got the disk out, we found the source of the bang was 1/4 of the face of the clutch had disappeared...seems it got hot from being together and swelled...the fact that I hadnt pushed in the pedal so the pressure plate was still squeezing it had let it get hotter and hotter and still hold together until I released the pressure and BANG!
The wavy middle part of the clutch was pressed flat...there is a name for that...found this:
Much clearer that what I wrote...that quote is from:
http://www.tpub.com/basae/91.htm
If you re seeing faster wear than you expect is normal in addition to the chatter, I would get a new clutch plate ready to install...
If it is a 230 truck, pulling the trans with the engine after some of the front sheet metal is off WILL make your life easier...believe it or not.
