Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Heat, defrost?
    Default Heat, defrost?
    Has anyone figured out how to make the defrost ducts yet? I will have to try to tackle this myself soon if i cannot figure out an easy way.
    I am thinking about making a long narrow box out of thin sheet metal and welding a round piece of stock for the ducting.
    What have other done?
    I have the heater in and seems to blow alot of heat. now I just need to get the heat the to defrost.
    1968 M715
    1952 M38
    Feb 2009
    Northern California
    I made mine from some plastic sheet, heated with a heat gun (it needs a temperature a lot higher than the air will normally get to), and curved into shape... something like:
    \_/
    | |__
    )_______)
    for the driver's side, with the diameter of the round part the same as the ID of the flexible duct hose I was using, and an end lip to stick the hose on. For the passenger side, I made it in a C shape with a round part on the end to attach the duct, and used the front of the dash as one of the sides - less fabrication, and makes the area in front of the passenger's handle all nice and warm.
    Thin sheet metal and a few rivets would have worked well too - rather than welding separate pieces together, you can make all from one piece pretty easily, and just need to tack weld or rivet a couple places.
    --Randy
    Jester Guest
    Quote Originally Posted by chrisnwmsu View Post
    I have been watching ebay for a set to come up and nada. If you decide to make a set, make a few. Sure there are quite a few of us that would like to get some.
    Quote Originally Posted by Jester View Post
    I think I am going to try to tackle the project myself. I am headed to my parents for Thanksgiving and plan to steal my dads 110 welder.
    I will make sure to post pics. If I can figure out a pattern and they seem to work I would be more then willing to make a few sets for the cost of the matteral + shipping.
    If anyone else has any ideas let me know.
    1968 M715
    1952 M38
    http://www.shopvac.com/shopvac-acces...906-75-00.aspx
    I am installing shop vac nozzles. They fit perfectly. Openings point forward, towards the firewall. I need to get some self drilling/tapping screws.
    Be sure the clear plastic, under the rubber seal that's between the window frame and the dash top, has been removed.
    I'll measure & post the width of the nozzle when I get home.
    Justin
    Those nozzles a few have used in the past...never heard of problems.
    Jester Guest
    I thought the shop vac part had to be cut and reworked to fit right?
    Quote Originally Posted by Maingear View Post
    Justin
    How do/did you secure the nozzles under the dash? Where did you put the screws? Pics????
    1968 M715
    1952 M38
    The only problem with the shop vac nozzles is that they do not have a mount tab on each end of them and they are slightly narrower than the actual opening. Not a big deal, but not an exact fit. I also think, but have not actually tried it, that the RH one would have a fitment issue with the glovebox in the way.
    If I ever get that far along, I do plan on making a set, though I've threatened to do it for nearly a year now, and making them from aluminum. If and when I do, I plan on posting up the measurements and specs.
    Stay tuned for more information........
    Jan 2007
    Fort Smith, Arkansas
    I've bought two sets on E-bay. I got one for around 50 and the second for 30. I figure I can spend a lot of time making something sort of close or just pony up. Seems like Italylovers was the seller. I requested a buy it now from them and got the 50 dollar price. It might have been another seller, but I think I remember correctly.
  1. windshield defrost
    By mstaley in forum Stock Tech
    Last Post: August 8th, 2009, 04:31 PM
  2. Defrost ducts questions
    By Kamikaze12volts in forum Stock Tech
    Last Post: December 31st, 2008, 10:58 AM
  3. Defrost tubing
    By fng in forum Modified Tech
    Last Post: May 15th, 2007, 06:59 PM
  4. lack of defrost
    By IAN_M715 in forum Stock Tech
    Last Post: January 29th, 2007, 01:35 PM
