Results 1 to 9 of 9
Thread: seanjames : GVW
    Re: GVW
    Post by brute4c on Dec 13, 2006, 11:16pm
    8400 for a non winch M715
    8900 for a winch M715
    8500 for an M725
    8900 for a non winch M726
    9400 for a winch M726
    Default goose :
    Re: GVW
    Post by goose on Dec 14, 2006, 9:13am
    The GVW is what the vehicle weighs as it sits there with various equipment.
    The GVWR is what the manufacturer has rated the vehicle to weigh with whatever load you can put on it. Or the max the vehicle can weigh with load.
    The law you refer to is for the GVWR. Basically it was designed to exept commercial motor vehicles because once you get over 10,000 GVWR and are used in interstate commerce, your a commercial vehicle. Not very many sigle axle trucks are over 10K GVWR, typically has to be a dually before the manufacturer will rate it over.
    Looking at the other link I would say the GVWR is 8900for the M715 with winch. However the M726 w/w is 9400. Thats the same frame and drivetrain, but higher rating. So I don't think there really is a rating listed by Jeep/Kaiser.
    Default elwenil :
    Re: GVW
    Post by elwenil on Dec 14, 2006, 9:42am
    Hmm, I wonder if the M726 didn't get different springs or something?
    Also, 10K lbs and up GVWR for light duty trucks is a fairly new deal and hasn't been around very long. The new Dodge Chassis Cab can be had in a single rear wheel configuration with a GVWR of 10,200 lbs and with the dual rear wheels it goes up to a max of 12,750 lbs when properly equipped.
    Re: GVW
    Post by brute4c on Dec 14, 2006, 9:49am
    The numbers I gave are the numbers given by Jeep for the G890 series for the GVWR.
    The GVW numbers are:
    M715:
    WOW: 5500
    WW: 6000
    M725: 6400
    M726:
    WOW: 6500
    WW: 7000
    Payload, Cross Country, Limited:
    M715, all: 2500
    M725: 2000
    M726 all: 2000
    Payload, Highway:
    M715, all: 3000
    M725: 2000
    M726, all: 2500
    I can break that down by GVW and GVWR by each axle if needed.
    Default seanjames :
    Re: GVW
    Post by seanjames on Dec 14, 2006, 11:13am
    Looks like the truck I'm looking at is a 724 so is the GVWR the same as ?
    Re: GVW
    Post by brute4c on Dec 14, 2006, 11:40am
    M724 is listed as:
    GVW, WOW: 4800
    GVW, WW: 5300
    GVWR Cross Country, Limited:
    WOW: 8400
    WW: 8900
    GVWR, Highway:
    WOW: 8900
    WW: 9400
    Payload Cross Country: 3200 for both models
    Payload Highway: 3700 for both models
    All of the above numbers EXCEPT the GVW include the weight of whatever body would be added to the truck and allows 400 pounds for a 2 man crew.
    The GVW is without any additional body other than the cab and without the crew allowance.
