Results 1 to 9 of 9
Thread: joesco715 : M715 Generator vs one-wire Alternator
    Default joesco715 : M715 Generator vs one-wire Alternator
    Post by joesco715 on Dec 11, 2006, 7:53pm
    Folks,
    I would like some advice with regards to the charging system of the 715. My 715 which has the Hercules Diesel conversion has the stock Generator.
    When I had my two M37's, one of the first mods I made was to convert the charging system to a one-wire delco alternator which greatly improved the charging system on the trucks.
    Does this hold true for the 715's or should I leave well-enough alone?
    Thanks for any comments or suggestions!!!
    Merry Christmas to all.
    Default sermis :
    Re: M715 Generator vs one-wire Alternator
    Post by sermis on Dec 11, 2006, 8:03pm
    Running 12 or 24 volt?
    Default joesco715 :
    Post by joesco715 on Dec 11, 2006, 8:07pm
    24v
    Default stanman :
    Post by stanman on Dec 11, 2006, 8:19pm
    thats a good question. I am always worried about my generator crappin out on me.
    Default k8icu :
    Post by k8icu on Dec 11, 2006, 10:06pm
    The M715 has a altinator not a generator and voltage regulator like the M715 has. If it's working I'd leave it alone.
    Default stanman :
    Post by stanman on Dec 11, 2006, 11:36pm
    I thought it was a generator??? Say if it did crap out and you needed a replacement, what would you use for a replacement?
    Default gimpyrobb :
    Post by gimpyrobb on Dec 11, 2006, 11:50pm
    Mine was dead when I got it. I'm now running a 24v onewire @ 100amps. Kind of pricey at 250.00.
    Default stanman :
    Post by stanman on Dec 11, 2006, 11:54pm
    ouch!where do you get one of those?
    Default adk4x4 :
    Post by adk4x4 on Dec 12, 2006, 8:36am
    For the Technical guys, the M-715's were fitted with 28V, 60amp alternators. The difference is what's "generated" in the coil. alternating current AC or direct current DC. AC is then rectified to DC in alternaor.
    The question you need to ask is what will I be doing with my 715?
    - primary offroad with deep fording option -> stick with stock
    -everyday driver, staying 24v not much water -> consider modern 24v alt when stock craps out.
    Either way I would cross that bridge when you come to it.
    Some repairs to the stock alt are not that hard or expensive either.
  1. joesco715 : Stripping vs Blasting and other ?'s
    Last Post: November 13th, 2009, 02:54 PM
  2. Generator
    By gregolma715 in forum Stock Tech
    Last Post: May 3rd, 2009, 12:05 PM
  3. generator instead of alternator
    By fwdstuck in forum Stock Tech
    Last Post: April 16th, 2007, 09:46 PM
  4. Alternator Hot Wire
    Last Post: April 2nd, 2007, 05:22 PM
  5. Swapping the generator with a 24 volt alternator.........
    By Nuke_battlewagon in forum Modified Tech Archives
    Last Post: April 22nd, 2004, 10:36 PM
