Results 1 to 10 of 13
Thread: dxeflyr : Jerry cans
    Default dxeflyr : Jerry cans
    Jerry cans
    Post by dxeflyr on Jun 29, 2006, 9:39pm
    I bought a couple of Jerry cans and holders, and mounted the left side yesterday. I was looking at the right side of my truck, though, and there's no mounting holes... is this stock, or were the original holes filled in by some PO? Thanks.
    Lone Pine, CA
    Default luckypabst :
    Re: Jerry cans
    Post by luckypabst on Jun 29, 2006, 9:47pm
    No holes, passenger side.
    Default dxeflyr :
    Re: Jerry cans
    Post by dxeflyr on Jun 29, 2006, 10:00pm
    Crap. There goes $50 I didn't need to spend, I guess. Is anyone else running cans on the right side, and how did you attach them?
    Lone Pine, CA
    Re: Jerry cans
    Post by luckypabst on Jun 29, 2006, 10:21pm
    I've seen it done and think it looks good, personally. Just layout the holes on the right side, same as the left and go to town.
    Default binfordm715 :
    Re: Jerry cans
    Post by binfordm715 on Jun 29, 2006, 11:52pm
    Mine has the holes (military or PO must have put a jerry can holder on there before). Since it isn't perfectly stock, naturally I had the holes painstakingly filled in.
    J/K.... I'm putting a jerry can holder on both sides. Never can have too much gas. Of course you know what I mean....
    Default bigwheelbob :
    Re: Jerry cans
    Post by bigwheelbob on Jun 30, 2006, 7:01am
    I have seen the holes on both sides, weather put ther by the po, or the factory.
    Default barrman :
    Re: Jerry cans
    Post by barrman on Jun 30, 2006, 7:52am
    I put mine on the passenger side. I just measured how far back and how far up the upper front mount hole was on the drivers side and copied it on the passenger side. Then I bolted in the mount with that one bolt, leveled it, marked and drilled the rest. You will need one footman loop to complete the can tie down.
    I originally wanted to make a Mermite can mount on the passenger side and use it as a cooler. But, they are just a little (less than an inch) too big to fit between the fender flare and the front bed frame. I then wanted to make a military Gerry can style water container work as a water carrier. I couldn't figure out an economical way to seal the inside up and insure the water would be drinkable. I did get as far as putting an Igloo water spout inside of one though.
    I think the dual Gerry cans makes the truck look balanced.
    Default elwenil :
    Re: Jerry cans
    Post by elwenil on Jun 30, 2006, 7:56am
    I'm not sure what you are getting at with the "military Gerry can style water container". You do know you can get the water containers that look and fit just like the fuel cans, correct? Brand new plastic and work really well from what I am told.
    Silver Lake Sand Dunes MI
    Default beast :
    Re: Jerry cans
    Post by beast on Jun 30, 2006, 8:24am
    When I bought mine, someone had drilled and bolted an extra mount on the passenger side. When I unbolted everything for sand blasting it was OD green under it. So either the military put it on, or the PO did before he painted the truck. I like the look of it, it helps break up that big open space between the fender flare and bed corner.
    Default barrman :
    Re: Jerry cans
    Post by barrman on Jun 30, 2006, 8:45am
    Lanty, yeah I know about the plastic water jugs. I just like the old metal ones with the huge cork sealed flip cap.
  1. Super bling jerry cans
    Last Post: July 2nd, 2015, 02:35 PM
  2. fastfrankie : Pictures of Jerry Cans on Both Sides
    Last Post: November 12th, 2009, 07:33 AM
  3. How many cans?
    By chicklin in forum Open Discussion
    Last Post: November 30th, 2008, 12:11 PM
