Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
Thread: wrecker : 205 T case brake conversion
  1. #21
    Re: 205 T case brake conversion
    Post by brute4c on Jun 21, 2006, 1:02pm
    Here are spicers 205 disc ebrake pics...sorry I havent found the text yet:
  2. #22
    Default socal715 :
    Post by socal715 on Jun 21, 2006, 1:14pm
    Caliper/rotor/master seems like a heck of a lot of work just for a E-brake..... why not just put a line lock in it and be done???
  3. #23
    Default elwenil :
    Post by elwenil on Jun 21, 2006, 1:36pm
    That's Spicerfab. Tom probably did it that way just because he had the junk sitting around and he was bored, lol.
  4. #24
    Default rpgdeity :
    Post by rpgdeity on Jun 21, 2006, 2:17pm
    Line lock is nice to have, but if for some reason you lose hydraulic pressure, then you have no parking brake, or regular brakes. I like having the mechanical T-case brake as a parking and emergency brake. Thinking of the worst possible situation, if you lost hydraulic pressure and also broke a rear driveshaft, then you would really be in trouble. The safest route in my opinion would be a mechanical parking brake that goes to the axle, but since that isn't really an option with the stock 715 rear axle, I think the next best bet is the mechanical T-case brake.
  5. #25
    Default socal715 :
    Post by socal715 on Jun 21, 2006, 2:27pm
    Yeah, but if you lose pressure.. you have daddy issues... and you're screwed anyways no matter what you're running.
  6. #26
    Post by brute4c on Jun 21, 2006, 2:30pm
    Most states dont call a line lock an emergency brake legally either because it relies on the same fluid as the regular brakes...they want to see a backup system that is totally seperate so that if the primary fails, the backup is still A1.
  7. #27
    Default socal715 :
    Post by socal715 on Jun 21, 2006, 2:41pm
    Very good point Jon. However, here in Kalifornia we ran them on our rigs.. but i guess never had anyone ever want to inspect them either.
  8. #28
    Default bigwheelbob :
    Post by bigwheelbob on Jun 21, 2006, 2:48pm
    Alot of line locks will loose preasire when left for any length of time also.
  9. #29
    Default socal715 :
    Post by socal715 on Jun 21, 2006, 2:49pm
    Yep and they will kill the batteries too. I never used them for any lengthy period of time. I guess im talking about offroad rigs in general.
  10. #30
    Post by brute4c on Jun 21, 2006, 2:51pm
    If it is strictly for off road, I think its a great idea....or even if there is a working mechanical ebrake....then one can add a line lock and have the best of everything to pick from...cover all the bases....thats is what I intend to have...................................someday.... .........................
  1. 200 to 205 brake drum conversion
    Last Post: October 17th, 2015, 09:46 PM
  2. 14 bolt brake conversion
    Last Post: April 16th, 2009, 04:49 PM
  3. 8 lug and disc brake conversion
    By perdidobob in forum Modified Tech
    Last Post: November 4th, 2008, 08:18 AM
  4. Stock Dana 70 disc brake and 8 on 6.5 lug pattern conversion
    By PaulC in forum Modified Tech Archives
    Last Post: April 20th, 2004, 12:35 PM
  5. Pro Tool Disc Brake Conversion Price
    By kalikraven in forum Open Discussion Archives
    Last Post: February 15th, 2004, 11:55 AM
