Results 1 to 10 of 18
Thread: binfordm715 : Now what do I do?! (Holley 1920 rebuild)
    Default binfordm715 : Now what do I do?! (Holley 1920 rebuild)
    Post by binfordm715 on May 23, 2006, 12:23am
    Well now what?!
    The "pump diaphragm & rod assembly" I get in the kit is on the left. The old one, with the now torn-up gasket material, is on the right. See what's on the paperwork that came with the kit? That's right....just like mine. 'Course the NOS kit is probably as old as I am (eBay find), though unopened. I'll see if NAPA can do anything for me.
    Also, the fuel input is different. There's a "fuel inlet seat 'O' ring seal" that I have on my "fuel inlet needle & seat assembly" that this kit doesn't include. At least that part isn't on the drawing too!
    No one has any quick-n-dirty ideas about dealing with this, do they?
    Re: Now what do I do?! (Holley 1920 rebuild)
    Post by brute4c on May 23, 2006, 9:41am
    Does Al's truck have a 1 barrel? How good are you at stealthly carb work?
    Sorry to hear it Tim...that sucks...I hope there is an answer out there that isnt a big headache...
    Who did you get the kit from? Was it an individual or company? Might help others avoid the issue...
    Tried AB Linn? Cant say it will help but cant hurt....
    Default robsgp :
    Post by robsgp on May 23, 2006, 8:31pm
    Got my NOS kit from Saturn Surplus. It had the correct pump diaphragm and rod assy though I came awful close to shooting that little BB across the garage reassembling it. The kit also came with a complete fuel inlet needle and seat assy with a gasket by the hex head and o-ring on the body. My big question is where the pump rod sticks out the back of the carb there is a little plastic cam that looks broken off and nothing attached to it??
    Lone Pine, CA
    Default luckypabst :
    Post by luckypabst on May 23, 2006, 10:24pm
    That's the pump cam, seems to be commonly broken. Mine was and Jon hooked me up in my time of need. Probably your best bet is to find someone with a spare that dosen't mind parting with the cam.
    Post by binfordm715 on May 24, 2006, 1:11am
    You had me scared there, guys! But it looks like my pump cam is in good shape. Looks new, I notice.
    Well, there's one thing that went my way!
    Anyone got a spare O-ring for the fuel inlet needle and seat assy? I can get one at NAPA for $0.99, plus $7 for shipping!
    Post by brute4c on May 24, 2006, 9:38am
    Thats the accelerator pump arm...I have seen a few in a white/yellowed color...
    When I bought my truck it had a dead spot off the line...traced to the acelerator pump arm being broken...so I found a junkyard 230 with a good pump arm and swapped that on...lasted about 2 years, then it broke...so then I had to buy a "rebuilder" carb with a good arm on it to get another one...BUT instead of mounting that arm to the carb, thinking it would only break again, I took it to the local machine shop and had them make one out of aluminum...no more problems.
    I sent the stock type arm to Chris...the aluminum one went with the carb out east when I changed to the 2 barrel setup...someone else needed the whole thing.
    Default robsgp :
    Post by robsgp on May 24, 2006, 8:00pm
    Mine was the yellowed broken plastic variety. Maybe I'll try making one. Great information thanks. BTW, Tim I do have an extra o-ring. Evidently my kit came with the whole assy and o-ring and gasket. You can have it. I just signed up to attend FE or I can mail it if you want it faster. Just email.
    Rob
    Post by binfordm715 on May 25, 2006, 12:11am
    Hey, if you need me to pull that cam thing off of there to trace it and measure it, just say the word. Wish I had a spare for ya!
    BTW, NAPA was able to scare up the correct pump diaphragm & rod assembly from a store in Seattle, so that's done. Just that pesky gasket that had me held up.
    I'm trying to do some research on this blasted thing to come up with some NAPA part numbers or something. When I go back to hound them tomorrow (actually, to take a digital pic of that dummy machine gun), I'll see if they have that cam available too.
    Default robsgp :
    Post by robsgp on May 25, 2006, 8:35am
    It went in the mail box today. Thanks for the offer to trace the part, but the picture you posted is so clear, and mine is just broken off where the rod from the accelerator attaches. I'm hoping to guestimate it and use a piece of coat hanger to connect it. If you do run across one though, I'd be very interested in buying it.
    Default jeepistdougiowa :
    Post by jeepistdougiowa on May 25, 2006, 9:17am
    I have a couple partially parted out carbs, if those parts are still on them I'll bring them to the FE.
  1. binfordm715 : Correct carburetor kit found!!! (Holley 1920)
    Last Post: November 11th, 2009, 02:58 AM
  2. Holley 4bl Carb, AMC 360 - Carb rebuild time?
    By BubbaWilkins in forum Modified Tech
    Last Post: July 6th, 2009, 11:54 AM
  3. 1920 Holley Carb on the M715
    By Captain Jack in forum Stock Tech
    Last Post: January 24th, 2009, 05:27 PM
  4. 1920 carb fuel bowl inlet baffle
    By FrankyD in forum Stock Tech
    Last Post: October 24th, 2007, 10:09 PM
  5. 1920 Carb Replacement
    By generalcuz in forum Stock Tech
    Last Post: October 2nd, 2007, 11:29 PM
