Page 4 of 4 FirstFirst 1234
Results 31 to 39 of 39
Thread: binfordm715 : Soft-top mount on windshield
  1. #31
    Default elwenil :
    Re: Soft-top mount on windshield
    Post by elwenil on May 17, 2006, 9:09am
    Actually in the pic above, the little dryrot crack running along the gasket is in the "hinge" for the lock that holds the glass in tight. If this get's bad enough, about the only thing that holds the glass in is the fact that the gasket has gotten hard. It will probably leak, and if not al the way into the interior, it will lwak on the outside so that water sets in the gasket and rusts out the lip that the gasket goes over on the frame. I would at least pop out the glass and replace the gasket when you repaint to inspect for rust and paint this problem area.
  2. #32
    Default teking :
    Post by teking on May 17, 2006, 9:23am
    The very reason I removed my glass when I repainted my frame.
  3. #33
    Default amphi :
    Post by amphi on May 17, 2006, 10:04am
    Little fuzzy but maybe this helps.
  4. #34
    Default socal715 :
    Post by socal715 on May 17, 2006, 10:31am
    I emailed you some useless pics Tim.. Amphi's are better... my top was on when i took the pics.. so i just peeled it back a little.
  5. #35
    Post by brute4c on May 17, 2006, 11:09am
    I guess the other thing you might need to know is the height from a fixed reference point...thinking about the windshield wiper motor mounts.
  6. #36
    ...and Nice Pics Amphi!!
  7. #37
    Default amphi :
    Post by amphi on May 17, 2006, 12:03pm
    Thanks brute!!!
    Camera wanted to focus on the background -- oh well. There is some white paint build-up on the front edge making it look like a different shape. The channel opening is the same for front and back
  8. #38
    May 2004
    Anchorage, Alaska
    Default 40grit :
    Post by 40grit on May 18, 2006, 8:48am
    TimDToolman,
    I can look around, if I find some 1/2' square tubing at Homedepot or such, I can get the machinists at work to mill the groove then you just drill a bunch of holes thru the windshield frame and spot weld the tube to the front of the frame...maybe even run a bead across the top to keep water from getting behind it and letting rust pry it off again...
  9. #39
    Default binfordm715 :
    Post by binfordm715 on May 20, 2006, 11:47am
    Thanks, gritty! I'll let you know if I need to go that route....
  1. binfordm715 : Need mirror arm mount dimensions
    Last Post: November 12th, 2009, 04:13 AM
  2. binfordm715 : Blackout Driving Light base mount
    Last Post: November 11th, 2009, 06:48 AM
  3. Replies: 3
    Last Post: April 8th, 2009, 07:54 AM
  4. soft top attachment to windshield
    By mojomot in forum Open Discussion
    Last Post: January 18th, 2008, 04:37 PM
