Page 4 of 4 FirstFirst 1234
Results 31 to 40 of 40
Thread: binfordm715 : HELP!!! I'm in turn signal hell
  1. #31
    Default binfordm715 :
    Re: HELP!!! I'm in turn signal hell
    Post by binfordm715 on May 3, 2006, 7:40pm
    Stock horn still works (most of the time, anyway!) and there's a Packard-capped hot wire #85 under the dash too. After reading your mention of it, I thought maybe they'd cut it behind the firewall leaving the under-dash part dead. But it tested hot. Hmmmm.....
  2. #32
    Post by brute4c on May 3, 2006, 9:56pm
    If there isnt a wire straight off the bttery, or a non stock wire off the battery side of the foot starter switch, it has to be in this wire somewhere that it is spliced from as this is all that is live BEFORE the on/off switch is switched on:
    Maybe they soliced into one of those wires, the horn or #85, and made a "Y" at that point...so the original is still working and the other is there too...maybe....
    Maybe they tpped the wires that run to the on/off switch, the 2 #11 wires...
    If it were me, cause I am tht way, I would look for it...
    As long as it is taped off and secured, its ok though of course...
  3. #33
    Post by binfordm715 on May 3, 2006, 11:19pm
    Maybe someday..... But it's all secure and happy now. I suspect one of these days I'll be tearing deeply into the truck and I'll see about dealing with it then.
    Took Nick to his Cub Scout meeting in the M715 tonight. Only two other Scouts at the meeting. Pretty lame pack, actually! We were talking about projects the boys could do. I suggested I could bring a box of 220 grit sandpaper and let the boys go at the M715! Heh, heh, heh.... J/k though.
  4. #34
    Post by brute4c on May 4, 2006, 8:20am
    Funny...thats one way to get de-yellowed!!
  5. #35
    Default thetroublemaster :
    Post by thetroublemaster on May 4, 2006, 8:33am
    Tim, If you have to press hard on the pedal to activate the pressure switch that means its going bad. I have to replace them on my CJ pretty frequently. It should only take light pressure to close the contacts. Before you install it turn the switch upside down and fill it with brake fluid first. If you have not done all that already.
  6. #36
    Post by brute4c on May 4, 2006, 8:38am
    The specs on the switches list 60-120 psi as the activation level...even the stock brake system has many many times that pressure....
  7. #37
    Default elwenil :
    Post by elwenil on May 9, 2006, 8:34am
    Just out of curiosity, what does the whole Solid State turn signal set up run these days? I know Jon posted that it was about $100 from Star Electric in the tutorial, but I assume that was when the page was put up. Saturn has this stuff for about $150, but if I can save $50 I will, but if not I'll order from Saturn along with a few other items I need.
    I tried calling Star, but all I get is an answering machine.
  8. #38
    Post by binfordm715 on May 9, 2006, 2:45pm
    Including shipping, it was $150 to my door, which included the turn signal switch, the harness with all female Packard connectors and identified wires, and the brain box. That was from Star Electric.
    Kevin (at Star) might be traveling. He gave me his cell number, but I don't have it with me. Be patient with him! I had to be. But he came through in the end.
  9. #39
    Default elwenil :
    Post by elwenil on May 9, 2006, 3:53pm
    Oh well, I already ordered it all from Saturn along with the other crap I needed. Along with almost $300 in Autometers from Summit. This d**n truck had better be worth it, lol...
  10. #40
    Default k8icu :
    Post by k8icu on May 10, 2006, 6:34am
    I know Kevin from Star. We use to hang out together at one of the MV show that use to be here in Ohio. I knew him before he became Star Electirc. He's a good guy and a straight shooter. He's a retired Army officer and he might be out on the road traviln to MV shows I know he does alot of them.
  1. Turn Signal Switch
    By fng in forum Modified Tech
    Last Post: December 9th, 2012, 09:43 PM
  2. My turn signal blinker is.........
    By viperman in forum Stock Tech
    Last Post: June 24th, 2008, 03:56 PM
  3. Turn Signal Distribution box.
    By Kaisercal in forum Open Discussion
    Last Post: May 28th, 2008, 07:48 PM
  4. Video: 12v Old Style Turn Signal Box
    By amphi in forum Modified Tech
    Last Post: March 28th, 2008, 01:11 PM
