Results 1 to 10 of 13
Thread: 715 headlight problems
    Default 715 headlight problems
    I have a '67 715 in which the headlights will only stay on for 3 minutes. Then what I would call a breaker heats up, cuts the power, and the headlights go out. After a few mintues the headlights will work again. Does anyone know where I can find this breaker to replace it with a fuse and how it can be identified where it's at? Or is it some other problem? I don't want to think it's the wiring harness.
    Feb 2009
    Northern California
    Good timing - I just wrote a bit on how to rebuild one of those switches!
    http://pages.suddenlink.net/randygar/switch/switch.html
    In short, take the switch apart, and sand the contacts of the breaker clean. If you're using 12V lights, or oversize bulbs, you can replace it with a larger breaker...
    --Randy
    replace the 3-lever switch. The circuit breaker is inside the switch.
    Quote Originally Posted by randygar View Post
    Neat write-up, Randy! Thanks! Lots of pictures too. Gotta love it!
    -- Tim Taylor
    I only skimmed the rebuild article for now I will go through it later how'd it seems to confirm there's an internal circuit breaker and that is been popping and resetting on mine once it's been driven for a while at night thanks guys
    Quote Originally Posted by noreallyicanfixit View Post
    Did you put any more bulbs into the circuit, maybe some halogen lamps? Excess current draw can open the breaker. It is just doing its job if so.
    I had a 3 lever switch do something similar...the time frame varied from a few seconds to maybe not at all that time...i replaced the switch and took it apart to find the metal bar that is the inside of the unlock lever had come loose and would wiggle itself into touching other things in the box and cause a short.
    once changed, poof...all was good...hope yours is just as easy!
    West-central Ohio
    Same here, Jon, mine fried big time inside, glad it didn't take more of teh harness with it!
    Amen...nuff people have had that fun already...
    New Haven, CT
    I have the same problem with the internal breaker tripping. LED headlights will give both better lighting and lower current draws, fixing two problems in one shot
  1. 7 Round H4 Headlight Conversion
    By Tomahawk715 in forum Modified Tech
    Last Post: December 10th, 2009, 11:28 PM
  2. Headlight springs
    By Chumley in forum Stock Tech
    Last Post: August 20th, 2008, 09:02 PM
  3. Headlight switch breaker?
    By the1968jeepthing in forum Stock Tech
    Last Post: November 3rd, 2007, 04:13 PM
  4. multifunction headlight switch
    Last Post: June 13th, 2007, 09:46 PM
