I'm still playing around with the idea of 2 tanks. I was just looking at Drew's site because I'm thinking about adding EFI to my 460 and ran across his article about adding a 39 gallon bronco tank between the rear cross members. I also saw this done on 40 Grit's truck and it fits really well.
Anyway, 2 questions:
1. With the Ford in-tank pumps you can use a simple toggle switch to chose which tank to get fuel from - can this be wired to flip the gas gauge easily? Or am I better off running 2 gas gauges? I have the room in my modified gauge panel - just kills off the clock.
2. If I ran a metal line between the bed and the frame from this second tank to the stock filler (with some kind of adapter) would I be able to fill both tanks that way? Or am I better off running 2 smaller lines up inside the stock rubber hose (one for each tank but unseen with the cap on)?
Thanks for the help
Ron
