Another problem...
I went out to drive the 715 to work this morning and it barely turned over. I have two new interstate batteries, 6 months ago. Have not had this problem until I installed the heater.
I hooked the power to the "switch board" under the hood. The blower will run with the ignition switch off. I let the jeep run 30 min in my driveway. I then shut it off and when inside last night. When out this morning and turned over 4 times and dead.
Did I hook the power up in the wrong place? Should not drain if the blower switch is off?
What should I check?
I hope it is not the generator....
HELP
