Results 1 to 6 of 6
Thread: sprung wieght for coilovers?
    Jun 2009
    Douglas Wyoming
    Default sprung wieght for coilovers?
    Does any one know the sprung weight of an m715? I do not have access to any type of scale large enough to check corner weight for coil overs. any help here would be a ton of help! it is not mobile so I can not drive to a scale and check it even with unsprung weight. has anyone on this site used coilovers on an m715?
    BBC,Atlas6:1,1 ton axles,42TSL
    Coilovers have been used at least once...saw a couple pics on a different site...dont know the details.
    Springs, figure 80 to 100 pounds each.
    Axles, I guess in the 4-500 pound range complete with brakes.
    Tire/wheel combo 60-70 maybe?
    So roughly:
    (90*4)+(450*2)+(65*4)=1520
    roughly...
    Jun 2009
    Douglas Wyoming
    thank you for the input! although I believe you provided the un-sprung weight. and I need the sprung weight (body, frame, engine, everthing the springs hold up) if you can remember the web site where you found the previous coilover design I would be very greatful! thank you for the input
    Well...empty weight from the factry is 500 lbs according to te book...I weighed my truck on a scale with 1/4 tank of gas, canvas top, troop seats and a spare...5350 pounds.
    So...
    5350-1520=3830
    again...roughly...
    heres is a link with a touch of info:
    Coil Suspension
    The one I was thinking of before is a highly modified truck with a big diesel I think...might have been on one of the diesel boards.
    Jester Guest
    There is a blurb about a coiled rig on Pirate. You could try contacting the poster for more info. Let us know what you find out.
    http://www.pirate4x4.com/forum/showp...2&postcount=20
    Actually, the stock wheel/tire combo is around 120 lbs each.
  1. How to fix a sprung M715 door
    By Kaiserjeeps in forum Stock Tech
    Last Post: October 24th, 2009, 08:59 PM
