THe TH400 did come in an AMC pattern, but they are tricky to find and would need a 2WD extension housing and output shaft. The TH400 has no TV cable, only a switch for a kickdown ont he throttle pedal that engages a solenoid in the valve body to downshift into passing gear.
The 700R4 would need an adapter plate.
I have TH400 in mine and I love it. Works excellent and is a stout transmission.
Don't forget you will need to add a trans cooler, lines, and a shifter to the mix as well. A trans temp gauge isn't a bad investment either.
