Results 1 to 4 of 4
Thread: radiators
    Aug 2009
    muskego wisconsin
    Default radiators
    i have a 67 with a sbc 350 that keeps running hot. water pump, hoses, thermostat are new. radiator was checked no blockage. wondering if bigger radiator is needed, or if any one else had this problem.
    Springdale, Arkansas
    What size rad are you running? If it's still a stock sized, less than 4 row then yes that may be the culpret.
    Some guys use a Chevelle sized rad with a shroud and get good results. I did and had no problems. Have you done a block flush lately?
    Here ya go:
    Stock radiator swap?
    Aug 2009
    muskego wisconsin
    thanks for the help. found out i had a bad rad cap.
  1. Custom Radiators
    By spgirard30 in forum Modified Tech
    Last Post: May 31st, 2009, 10:59 AM
  2. BBC deuce trans swap (was radiators and more)
    By gimpyrobb in forum Modified Tech
    Last Post: December 31st, 2008, 11:36 PM
  3. radiators/hoses
    By willey10 in forum Modified Tech
    Last Post: January 11th, 2007, 08:11 PM
  4. BB and radiators
    By Mikel in forum Modified Tech Archives
    Last Post: March 24th, 2004, 11:33 AM
