I have found that most bedliner brands will build, if you let the first coat tack up good and use a really heavy nap roller. Not the plastic thing that comes with the kits. Get a roller that is made for painting cinderblock or stucco. It will get messy, but it will do the job even with the Dupli-Color cheap stuff. I did the inside of my Dodge van floor, and it turned out pretty good for an econo job.
The last coat you can do with the plastic roller in the kit for the texture if you want.
