Is it possible that the internals, bearings etc. are so worn that the pressure is not gonna be there with a new pump?
Usualy you would need a lot of miles...no idea ewhatyour motor has.
I have a spare motor in the shop that is locked up...I can pull the pump and ship to you if you want to pay a little for it...you could use it just to test and see if it does the same thing to see if it is the bearings...
Let me know.
