OK I did use the search and have read tons of the posts on here. I got some info that I was looking for, but not all. If the answers are covered in other threads and I missed it I'll apologize now.
So first off for a front axle is the mounting width of a DRW axle more desirable? I really only saw this talked about on the rear axle.
On a D60 king-pin 4 bolt front axle will are steering arms swap over?
Last is appears that going SOA is the easiest way to swap an axle in. But what are the best springs to use as to not get 5-6" of lift? I like the truck where it sits now. I'd like to keep it under three inches if I have to gain any lift.
