Thread: Rocker replacement spot weld questions
    Default Rocker replacement spot weld questions
    so i got my truck all torn apart last night and i am looking at the rockers that i need to replace and i notice that i cant really tell where the heck the top part are spot welded on?
    Anyone have pictures showing how to tell etc?
    The top of the rockers are spot welded along the top flange where it butts against the floor pan flange. There is also a seam at the curved portion on the front and rear. The bottom is spot welded along the part where it curves under and attaches to the inner rocker.
    so what is the best way to get these off besides a drill bit?
    Washington State
    If you search the forums you will find pictures of my custom 1/4" plate steel rockers. Fully welded to the undercab supports. They will never rust through or be dented. It was easier to do this than weld in stock type rockers.
    Apr 2008
    Noth Dakota, Fargo
    A small grinder such as a dremel or die grinder through just one layer worked for me, if you will be removing the rest of the metal. Grinding can leave big holes though. You can also get a spot weld cutter, a drill bit in essence. That will leave a hole small enough to re-weld.
    Rotabroach makes some really nice spot weld cutters that leave a clean hole and remove the entire weld.
  1. Rocker panel replacement
    By res0wc18 in forum Stock Tech
    Last Post: June 30th, 2009, 03:43 PM
  2. Rocker replacement pic's as promised
    By viperman in forum Open Discussion
    Last Post: May 21st, 2008, 04:51 AM
  3. Rocker panel, cab corner replacement ???
    By Elliott in forum Open Discussion
    Last Post: April 1st, 2008, 01:41 PM
  4. weld question
    Last Post: June 20th, 2007, 02:13 PM
  5. replacement rocker arms
    By IAN_M715 in forum Stock Tech
    Last Post: April 12th, 2007, 09:34 PM
