Thread: Check yer nuts
    Default Check yer nuts
    I know we've covered this before, but I did a nut and bolt check this week prior to leaving for the MVPA convoy and found:
    lower shock mount bolt front passenger side had backed out, allowing shock to wiggle around and contact shock tower.
    tranny mount bolt loose, allowing tranny so "roll over" under load. (wondered what that clunking noise was)
    oil pan bolts loose, etc.
    So - check yer nuts!
    67 M725 67 M715 68 M715
    My CJ has been broke ever since Sermis came for the FE in 2007. When I brought it home to fix the axle last month bmac and I found a oily bolt lying on the trailer. Turns out it was from the bellhousing. What I thought was a noisy throwout bearing was just the tranny about to fall out.
    And the msd cd ignition went out when I got it back as well.
    What a mess. Hopefully, next week I can get the axle fixed and get it back to the ranch.
    Bottom line: Don't let sermis ever drive your junk. It won't be same ever again.
    everything he drives is the same "drive it like you stole it" when we went to test drive my CJ i got out of it half way up the hill LOL
    My CJ never made it out of the hole at the bottom of the hill.
    Still haven't fixed that thing. Maybe I need to make a trip to the ranch...
    Come on out. It is getting closer. I have new one-piece axles. Just working on getting everything cleaned up to put it back together.
    He did shut it off as soon as he smelled oil and the pressure started down. It could have been worse. A lot worse.
    Rich, I agree with you about just crawling under the truck and trying to turn stuff every now and then. Good advice.
    yeah, if I had bothered to look under it the CJ once in a while, I would have seen the problem with the leaf spring that started the string of destruction. Sermis just happened to be driving it when it let go. As far as I can tell there is no problem with the motor. Just all the other stuff that shook loose after 3 years as a ranch jeep.
    Should be back at the ranch again in time for the 4th.
    Sermis, want to come out and give it a test drive? NOT!!!
  1. maddawg308 : Going nuts about my bolts...
    Last Post: November 11th, 2009, 04:10 AM
  2. nuts and bolts
    By vacca rabite in forum Open Discussion
    Last Post: August 16th, 2009, 08:24 PM
  3. Rusty nuts
    By 5quarter in forum Open Discussion
    Last Post: May 21st, 2009, 08:40 PM
  4. Axle Nuts
    By AEM67M715 in forum Stock Tech
    Last Post: September 2nd, 2008, 04:34 PM
  5. Lug nuts on the -715 - lefty loosey?
    By maddawg308 in forum Stock Tech
    Last Post: April 26th, 2007, 09:02 PM
