Your 3 lever switch is probably bad. I have had 2 do the same thing...inside the switch, there is a strip of metal that is moved by the unlock lever...sometimes it appears, this strip of metal comes loose and falls into a place inside where it can contact 2 live points inside the switch...circuit breaker pops with an audible click.
I was able to knock mine a couple times and get the piece to move and then the circuit breaker resets and things are ok until it happens again.
Change out the 3 lever...
